Drum to Disc Swap
Drum to Disc Swap
Okay, i just got done searching and i couldnt find a definitive answer on what i will need to swap from drums on my 06 extended cab
i broke the G80 a month or so ago and was planning to change the entire axle, i was wondering if while im at it i should just find an older silverado to pull the rear end out of with the discs and if i did that what would i need to make it all work? master cylinders proportioning valves abs? i know ill need e brake cables but beyond that im not sure. thanks in advance
Corvette454l88
09-01-2016 01:24 AM
mrgrim
07-08-2015 08:12 AM
