Dyno Testing Video From Flt
Here are a couple video clips I put together for you guy's to see our Dyno in action. This trans is one of our level 5 4l60E transmissions. With the use of this machine it allows us to give you the quality you deserve. It really is a quality control/research and development tool that we use to insure that when you get your transmission it works. These are pulls at different amounts of pressure.
The first one is at a 125psi.
This is a pull at 150psi.
This is a pull at 185psi.
This pull is at max pressure.
Thanks Bill
It is simulating how hard the trans will shift at different throttle angles. Basically as you watch the different clips, as I increase the pressure, you can see that I am running the trans harder as I go.
No sorry. That unit is a 5 year old unit that Chuck built way back. It was in for a freshen up special. I figured after I got done with the build I would shoot some clips for you guy's. Hope you liked what you saw.
You got that right. Very few shops own a piece like that. In are business I feel it is a must. It's nice when you get them and all you need to do is install it and it works. Vince
