EATON has arrived....
Old 06-07-2005, 07:48 PM
blownerator
BlownChevy's Avatar
Originally Posted by Tiburon
what are the advanteges over the 400 lb springs?
More holding power.
blownerator
BlownChevy's Avatar
Old 06-07-2005, 08:13 PM
1Blown04's Avatar
Cool Brian, hope it works well for ya!
Old 06-07-2005, 08:17 PM
11 Second Truck Club
Breeze's Avatar
Aea they the springs the green ones mine are exactly the same.
Old 06-07-2005, 08:39 PM
14 Second Truck Club
Originally Posted by 03silverado5.3
How do you know what pound you got? I just bought one and never knew anything about different levels. Are you going to change youre axles also?
The regular ones are 400 lb. If you didnt special order that is most likely what you got.
Old 06-07-2005, 09:08 PM
blownerator
BlownChevy's Avatar
Should be good to go!!
Old 06-07-2005, 10:10 PM
vanillagorilla's Avatar
There are 600lb'ers too. Just be careful goosing it around corners with the 800lb springs. Oooops
1slow01Z71, I would go with the 800's too. They're pretty agressive, but I think that heavier, hi-po trucks could benefit from it. When I was doing the rear in my car, I found that that's what most of the heavy Chevelle guys run. It might wear out a little sooner, but it tough to say, because the clutches won't slip as much. But they are constantly pre-loaded. I think they would be good for off-roading as well, because with the 800's its damn near like a locker.
Old 06-07-2005, 10:28 PM
blownerator
BlownChevy's Avatar
heh
Old 06-08-2005, 05:52 AM
creederado's Avatar
Originally Posted by BlownChevy
heh
Nice dif cover,
let us know how there O-ring set up works out.
Old 06-08-2005, 06:28 AM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
I seem to remembeer someone posting a diff cover that locks into the eaton to make it stronger. Does anybody know who makes it and the pn. I couldnt find it in the search. Is there anything else we can do to our rear ends to make them stronger without swapping out for a 14bolt.
Quick Reply: EATON has arrived....
