EATON has arrived....
Old 06-08-2005, 06:49 AM
  #21
leochevy2001's Avatar
I think it was the T/A diff cover. I think they have them on the Thunder Racing website--->
Old 06-08-2005, 09:20 AM
  #22
blownerator
BlownChevy's Avatar
T/A makes on that preloads the bearing caps.....It looks cool.....
Old 06-08-2005, 12:51 PM
  #23
14 Second Truck Club
I seem to remembeer someone posting a diff cover that locks into the eaton to make it stronger. Does anybody know who makes it and the pn. I couldnt find it in the search. Is there anything else we can do to our rear ends to make them stronger without swapping out for a 14bolt.
Weld the axle tubes 360* around the center, solid spacer, diff cover with the bearing cap preload, billet main caps(not sure if they are still available), main bearing cap studs instead of bolts. T/A was the originator of the cover ,but they also make private label versions for a bunch of people.
Old 06-08-2005, 06:01 PM
  #24
blownerator
BlownChevy's Avatar
Old 06-08-2005, 09:28 PM
  #25
Originally Posted by BlownChevy
It is all pretty easy to do stuff. None of it really adds that much strength, but combined it all adds up.
Old 06-08-2005, 09:29 PM
  #26
Leroy_454's Avatar
BlownChevy, could you post up the part number on that Eaton? Thanks.
Old 06-08-2005, 11:10 PM
  #27
blownerator
BlownChevy's Avatar
ED 19559-1
Old 06-08-2005, 11:18 PM
  #28
ED 19559-1
Just to clarify- If you call and order that part number you will get 400# springs unless you specify otherwise. The 19559 is the off-the-shelf part number, but they still use it as the base for the 800# units. The springs are the only thing they need to change, unless you go with carbon fiber clutches .
Old 06-08-2005, 11:20 PM
  #29
blownerator
BlownChevy's Avatar
Old 06-09-2005, 01:06 PM
  #30
12 Second Club
O3GMC's Avatar
you and your fancy eatons.....I just went for the $325 shipped ebay special
Quick Reply: EATON has arrived....
