ECSB 4WD 4l60E to 4l80E
Old 12-23-2008, 01:31 PM
  #251
Yogi Bear's Avatar
Originally Posted by howard quick
Yeah....the pushlok fittings are fine. No need for clamps. Infact...it's recommended clamps NOT be used when using 'Pushlok' fittings.
I've actually been using the Aeroquip hose and 'Pushlok' fittings for quite a while now with no ill effects (it was originally recommended to me by a hose manufacturer/supplier we use at work).
Is that with any properly sized hose or only the Aeroquip?
Old 12-23-2008, 01:47 PM
  #252
howard quick's Avatar
Not sure if they can be used/are appropriate for 'any' hose.
I used them on my fuel lines when replacing the pump with the Walbro but I used clamps as well for the very reason you've asked about.
There are different brands of 'pushlok' fittings also. Mine are a local brand called 'RYCO'. They are available in the 'Aeroquip' brand.
Old 12-28-2008, 04:17 AM
  #253
Installed the heatshield and made a couple of brackets to hold the steel lines secure.
Old 12-28-2008, 09:08 AM
  #254
KySilverado's Avatar
I didn't put my new heat shield on. It incorporates hangers for the exhaust on a 6.0L/80e combo that I don't have. When I re-do my exhaust I will take advange of them and use the shield.
I didn't get the lines running over the steering gear box at first. Dang RH Drive
Old 12-28-2008, 01:09 PM
  #255
Lol! Yeah.....GM took some 'shortcuts' with the RHD conversion!
Old 02-08-2009, 07:42 AM
  #256
zeake's Avatar
Great right up. This is going to help me tremendously. How is the 4l80 trans doing?
Old 02-08-2009, 07:52 AM
  #257
Thanks, Hope it helps you. The 80e is doing fine. I do have a mystery leak somewhere. Every couple of weeks it will decide to leave a small present on the garage floor and I cannot find where it is coming from.
Old 02-09-2009, 10:13 PM
  #258
AV8R27's Avatar
Surely you aren't tired of hearing this, but your write up has been an AMAZING piece of work. I often lose interest in something quickly is the information is presented in less-than-desirable fashion; I just read all 26 pages of this write up front to back without so much as a 'nature' pit-stop And I'm honestly no where close to doing the swap presented, lol. I've only got an 04 4.8 ECSB right now, but when the time comes...would like to do the 6.0/80E swap jointly. Sorry to semi-jack your thread sir...but you did a phenomenal job!!
Old 02-09-2009, 10:19 PM
  #259
charcold-bowtie's Avatar
lol I have a 4.8/80e now.
Old 02-09-2009, 10:28 PM
  #260
AV8R27's Avatar
And it's a bullet-proof 4.8 no doubt! With as much as I'd like to do to the engine now, and what I've read on here...I'd really like to go with a 6.0/80E transplant before I do any power mods...even with as bad as I'd like to throw in a full exhaust, cam, tune, etc...I'm going to be strong and save up the pennies and shoe in the 6.0 first... I can still go with the new wheels/tires and add that second tone of paint though=)
Quick Reply: ECSB 4WD 4l60E to 4l80E
