ECSB 4WD 4l60E to 4l80E
Old 03-21-2009, 01:33 AM
  #271
brent5631's Avatar
Hey KY just wanted to say thanks for the writeup. I just put a 6.0 and 4l80 in my 2wd 99 and your thread helped alot. the 4l80 is the first mod i did just so i didn't have to worry.
It would be sweet to see some more writeups, maybe NO2 or something!
Old 03-22-2009, 12:17 AM
  #272
DixieDevil's Avatar
From what I can see this should be the right pigtail for the speed sensor right? Just wanna make sure I snatc the right one.
Old 03-22-2009, 12:30 AM
  #273
howard quick's Avatar
Yep...that's it. Same plug as for the ECT(engine cooling temp) sensor.
Old 03-22-2009, 12:34 AM
  #274
DixieDevil's Avatar
Awesome! Thanks for the quick reply, I can go ahead and order it then! I love this place
Old 03-22-2009, 05:33 AM
  #275
GMCtrk's Avatar
hey, where are you ordering from, I need that front VSS too. Thanks
Old 03-22-2009, 12:54 PM
  #276
there is one under the hood that is not being used let me go see where I seen it at.
Old 03-22-2009, 04:09 PM
  #277
charcold-bowtie's Avatar
Over by the AC canister. Err theres a unused plug over there at least.
Old 03-22-2009, 04:26 PM
  #278
GMCtrk's Avatar
Ive seen that plug before. I was wondering wtf is was for.
Old 03-22-2009, 04:29 PM
  #279
nonnieselman's Avatar
Originally Posted by Yogi Bear
Don't you need hose clamps on those fittings?
Originally Posted by kbracing96
Push lock fittings are rated to 250psi most of the time with out clamps. They have large, fairly sharp barbs on them
Originally Posted by howard quick
Yeah....the pushlok fittings are fine. No need for clamps. Infact...it's recommended clamps NOT be used when using 'Pushlok' fittings.
I've actually been using the Aeroquip hose and 'Pushlok' fittings for quite a while now with no ill effects (it was originally recommended to me by a hose manufacturer/supplier we use at work).
Wanna know what happens when you put a hose clamp on PUSH LOK??
It leaves you sittin on side of the road with a busted hose..
i had hose clamps on my trans lines and if you tighten down the barbs on the fitting cut thru the rubber on the inside of the hose and you can imagine what happens after that
Old 03-22-2009, 06:34 PM
  #280
foxracingfreak's Avatar
Man what a great write up.. i just got done reading all 28 pages. this will help me out alot when i decide to do my 6.0/80e swap once my warranty is up. thanks alot for all the detailed pictures
Quick Reply: ECSB 4WD 4l60E to 4l80E
