ECSB 4WD 4l60E to 4l80E
#292
SPAM HUNTER
I did some BS searching with alldata, i found a 2005 Suburban 2500 2wd came with 80e I think when i do my swap from 5 speed to 80e swap. I plan to modify the ends to run hose fittings because i have to run a External cooler only.
Dustin
Dustin
#298
pretty much just starting. Gathering parts. I'll update the thread as i go along. I'm swapping to 6.0l lq4 should apply to all 4.8l and 5.3l lsx style engines. Along with and auto track nvg/np 246 rpo np8.
Parts/mods needed as i know them so far. I'll update everything with part numbers if i purchase them and know they work.
4wd 4l80e trans - has short output shaft and adapter for transfer case.
4l80e torque converter
bell housing cover
dipstick tube
4l80e flex plate
crank to flex plate spacer and the longer bolts
wiring mods to the main transmission connector (pigtails can be bought)
extra speed sensor connector, wiring and pins to connect to the pcm
32 spline input shaft for the transfer case. (you can swap output shafts in the transmission)
tune with 4l80e segment swap written to pcm after the swap.
4l80e transmission cooler lines or modify what you have
modified transmission cross member.
Modified/new driveshafts - rear shorter - possibly front longer
bell housing cover
dipstick tube
4l80e flex plate
