ECSB 4WD 4l60E to 4l80E
Old 05-23-2009, 09:18 PM
  #291
ramsey rider's Avatar
Im assuming these are gm numbers?Nice find btw
Old 05-23-2009, 09:49 PM
  #292
SPAM HUNTER
2005 Silverado's Avatar
I did some BS searching with alldata, i found a 2005 Suburban 2500 2wd came with 80e I think when i do my swap from 5 speed to 80e swap. I plan to modify the ends to run hose fittings because i have to run a External cooler only.
Dustin
Old 05-23-2009, 10:37 PM
  #293
KySilverado's Avatar
Great info Ray. I remember us talking about those lines. I'm kinda glad my line wound up being long. Kinda prodded me into going ahead and upgrading the cooler.
Old 05-24-2009, 08:56 AM
  #294
GMCtrk's Avatar
Originally Posted by 2005 Silverado
I did some BS searching with alldata, i found a 2005 Suburban 1500 2wd came with 80e I think when i do my swap from 5 speed to 80e swap. I plan to modify the ends to run hose fittings because i have to run a External cooler only.
Dustin
no 1500 suburban came with the 80e.
Old 05-24-2009, 09:36 AM
  #295
supersub's Avatar
No but the 2500 did.
Old 05-24-2009, 10:53 AM
  #296
SPAM HUNTER
Let me correct myself. I put 1500 but meant 2500. I wonder if a van configuration would work. I know some express vans came with 4.8 4l80's.
Dustin
Old 05-24-2009, 11:09 AM
  #297
supersub's Avatar
Dustin
As far as the cooler lines? Only trucks work. Van s/metal,suspension,and cooler locations are completely different.
Hd trucks to hd trucks.
If you want them to fit the reg trucks the 2500 burb/av are the ticket and p# are now provided.
Old 09-18-2009, 06:16 PM
  #298
Registered User
noahnevil's Avatar
Originally Posted by kysilverado
pretty much just starting. Gathering parts. I'll update the thread as i go along. I'm swapping to 6.0l lq4 should apply to all 4.8l and 5.3l lsx style engines. Along with and auto track nvg/np 246 rpo np8.
Parts/mods needed as i know them so far. I'll update everything with part numbers if i purchase them and know they work.
4wd 4l80e trans - has short output shaft and adapter for transfer case.
4l80e torque converter
bell housing cover
dipstick tube
4l80e flex plate
crank to flex plate spacer and the longer bolts
wiring mods to the main transmission connector (pigtails can be bought)
extra speed sensor connector, wiring and pins to connect to the pcm
32 spline input shaft for the transfer case. (you can swap output shafts in the transmission)
tune with 4l80e segment swap written to pcm after the swap.
4l80e transmission cooler lines or modify what you have
modified transmission cross member.
Modified/new driveshafts - rear shorter - possibly front longer
hey im new on here and im lookin for a 1991 chevy van transmission has to be out of that year they say it is a l4 80 e over drive thanks if you can help me
Old 11-28-2009, 02:38 PM
  #299
Banned
ryan_prettyman's Avatar
I am bringing this thread back up because I think I am going to get the 96 4L80E trans in the garage built for the 5.3 turbo motor that I have any thoughts?
Old 11-29-2009, 12:00 AM
  #300
howard quick's Avatar
It'd probably be cheaper to buy a good used 80E from a 2000+ vehicle. It'd already have all the factory upgrades.
Quick Reply: ECSB 4WD 4l60E to 4l80E
