ECSB 4WD 4l60E to 4l80E
Old 11-29-2009, 11:53 AM
  #301
Banned
ryan_prettyman's Avatar
I don't know a local trans shop said he would build it for $1000 and sell me a vigilante torque converter for another $1000!
Old 02-17-2010, 09:41 PM
  #302
idahoblkss's Avatar
Originally Posted by KySilverado
Went through the thread a totaled up the cost.
Used low mile 4l80E - $1073 shipped.
Transfer case input shaft 113.59 shipped.
15809057 Hose - part of the trans (didn't use)
15812029 Pipe - trans cooler hard line
15267484 Pipe - trans cooler hard line
15765623 Cover - bellhousing
15013290 Bracket - shifter cable
15832205 Tube - dip stick tube
15183801 Indicator - dip stick
15860239 Bracket - heat shield -(didn't Use) 267.98 with tax.
Transgo Shift Kit 110
Fluid 50
Filter 20
PI Converter 946 shipped
Trans Cooler 75
Used cross member to modify 75
Compression fittings 10
Spicer 1350 Rear Yoke, seal, and caps 70
Custom Drive Shaft - Rear 516
Stock front drive shaft 100
About $3427 and a butt load of work.
do you have a part number on that transfer case input shaft? or maybe a link to where you got it, thanks.
and will all of these parts be the same for my awd ss , thanks agian
Old 02-17-2010, 09:47 PM
  #303
GMCtrk's Avatar
Part # for the REAR cooler line: 15812029 (front cooler line from 60e supposedly bolts into 80e). Runs $33 at the stealership.
Old 02-24-2010, 11:32 AM
  #304
idahoblkss's Avatar
does anybody have a part number on that transfer case input shaft? or maybe a link to where you got it, thanks.
Old 02-24-2010, 01:46 PM
  #305
zeake's Avatar
You can get an awd transfer case input shaft from EADPerformance.com or Tim aka time2kill on silveradoss.com
Old 02-24-2010, 04:37 PM
  #306
idahoblkss's Avatar
i just want to know where he got his for $115 cause i have been quoted around $400 for one.
Old 04-30-2010, 10:36 AM
  #307
KySilverado's Avatar
The transfer case input shaft I got came from tbtrans dot com. I get lots of PM's for the source so thought I'd throw it in the thread.
AFAIK the input shaft is different for the AWD transfer case compared to the AUTO Trac transfer case I had so may explain the difference in price. AFAIK the company I got my shaft from does not carry the one for the AWD unit.
Old 06-01-2010, 09:48 PM
  #308
jiar577's Avatar
Subscribed, I'm considering this swap for my '06 1500 rcsb 4x4
Old 12-25-2010, 02:12 PM
  #309
Pony Exp.305's Avatar
Damn 31 pages..I ll read thru 32 pages later.subscribed
Old 03-06-2011, 07:20 PM
  #310
sharpshooter's Avatar
which 60e cooler line do you re-use for the front cooler fitting on the 80e? is it the upper or lower line on the 60e that goes to the front fitting on the 80e?
thanks for making this thread KySilverado
Quick Reply: ECSB 4WD 4l60E to 4l80E
