ECSB 4WD 4l60E to 4l80E
#302
Went through the thread a totaled up the cost.
Used low mile 4l80E - $1073 shipped.
Transfer case input shaft 113.59 shipped.
15809057 Hose - part of the trans (didn't use)
15812029 Pipe - trans cooler hard line
15267484 Pipe - trans cooler hard line
15765623 Cover - bellhousing
15013290 Bracket - shifter cable
15832205 Tube - dip stick tube
15183801 Indicator - dip stick
15860239 Bracket - heat shield -(didn't Use) 267.98 with tax.
Transgo Shift Kit 110
Fluid 50
Filter 20
PI Converter 946 shipped
Trans Cooler 75
Used cross member to modify 75
Compression fittings 10
Spicer 1350 Rear Yoke, seal, and caps 70
Custom Drive Shaft - Rear 516
Stock front drive shaft 100
About $3427 and a butt load of work.
Fluid 50
Filter 20
Trans Cooler 75
and will all of these parts be the same for my awd ss , thanks agian
#305
#307
AFAIK the input shaft is different for the AWD transfer case compared to the AUTO Trac transfer case I had so may explain the difference in price. AFAIK the company I got my shaft from does not carry the one for the AWD unit.
