ECSB 4WD 4l60E to 4l80E
Old 12-07-2012, 09:08 AM
  #361
I have a gauge for that
Atomic's Avatar
I actually was home....and drunk
99-02 style
03-07 style
Old 12-16-2012, 04:06 PM
  #362
RedRobinYum's Avatar
WOW what an amazing right up. trans went out in my truck and been waiting to do a 80 swap in my 4wd CCSB but was worried to death. Thanks alot i have to fear in doing it now. Thanks again
Old 03-25-2013, 07:58 AM
  #363
03sierraslt's Avatar
Originally Posted by KySilverado
This is what I've come up with for DS length and cross member modification. Lucky (or unlucky) enough to have an extra 65E laying around. Everything I've found on the net says the 60E should be 21.75 long. I've measured mine 3 times at 22 3/8.
Need to move the crossmember mount back about 2.5 inches. The DS shortened about 1.75 inches.
I got the same measurements for mine.
Old 03-25-2013, 08:01 AM
  #364
More crossmember pics.
Old 03-25-2013, 12:06 PM
  #365
Vortec350ss's Avatar
That looks great pat. How long before you do the swap? I'm going to order my new converter very soon. I'll get my swap done shortly after that.
Old 03-25-2013, 12:39 PM
  #366
Waiting on my billet input shaft then trans will be done, next month or so I guess. Waiting for weather to break before I get the truck back out.
Old 08-11-2013, 01:03 AM
  #367
TURBHOE's Avatar
from what i can find, that front shaft is from a manual truck. thats what comes up with the part number any way. is this true?
Old 10-19-2013, 02:42 PM
  #368
timmay208's Avatar
this is just the thread im looking for. Hoping to get a 4l80e into my 05 5.3 4x4
One big question i have maybe someone can answer is can i just use a transfercase from a 6.0 truck instead of putting new parts in my stock one?
what years of 4l80e parts do i need say for flywheel?
and what years of 4l80 trans do i want to stay away from?
Old 11-05-2013, 02:54 PM
  #369
V-seriesTech's Avatar
Awesome post. I have an 07 Tahoe Z71....and my boos just offered me a 4L80 with a transfer case attached to it.
I have been waiting on going turbo because of the 4l60 that's currently in it. Thinking long and hard about doing this swap now a little sooner. Just not sure if I should hold out for a 6l80 or if I should just be glad with what was just offered to me.
Old 11-07-2013, 07:36 AM
  #370
Registered User
nogo6's Avatar
Pretty much just starting. Gathering parts. I'll update the thread as I go along. I'm swapping to 6.0L LQ4 should apply to all 4.8L and 5.3L LSx style engines. Along with and Auto Track NVG/NP 246 RPO NP8.
Parts/mods needed as I know them so far. I'll update everything with part numbers if I purchase them and know they work.
4WD 4l80e trans - has short output shaft and adapter for transfer case.
4l80e torque converter
Bell housing cover
Dipstick tube
4L80E flex plate
Crank to flex plate spacer and the longer bolts
Wiring mods to the main transmission connector (pigtails can be bought)
Extra speed sensor connector, wiring and pins to connect to the PCM
32 spline input shaft for the transfer case. (you can swap output shafts in the transmission)
Tune with 4l80e segment swap written to PCM after the swap.
4l80e transmission cooler lines or modify what you have
Modified transmission cross member.
Modified/New Driveshafts - Rear shorter - Possibly front longer
So how much money u have sunk into ur whole 80 swap?
Quick Reply: ECSB 4WD 4l60E to 4l80E
