ECSB 4WD 4l60E to 4l80E
Old 02-26-2014, 05:25 PM
  #381
03sierraslt's Avatar
Originally Posted by 04likearock
seems to take more gas pedal to get the truck moving the same way it did before
Ya a little bit, once you get used to it you never notice. Allot depends on the converter also. Ill take a 80E any day of the week even in lower power setups as I dont care for the way a 60e acts on upshifts and downshifts.
Old 02-26-2014, 07:42 PM
  #382
11 sec. Truck Mod
TIM Z's Avatar
Amen , that's the truth and nothing but the whole truth .
I love the stock 80e/LQ4 in my van ,drives and shifts do nice .
The 80e is a real transmission , the 60e Not so much .
Old 03-24-2014, 03:21 PM
  #383
sicvic01's Avatar
Anyone know where to get the harness for the 2nd speed sensor? Thanks
Old 03-24-2014, 03:32 PM
  #384
timmay208's Avatar
i got my 2 wire plug on ebay
Old 03-24-2014, 04:12 PM
  #385
Ferocity02's Avatar
I got mine on eBay as well. It was advertised for a T56 but works on the 80E and 60E as well.
Old 03-24-2014, 04:20 PM
  #386
sicvic01's Avatar
So just search speed sensor harness on ebay?
Old 03-24-2014, 04:30 PM
  #387
Ferocity02's Avatar
Here's one: T56 6 SPD VSS Vehicle Speed Sensor Wiring Connector Plug Pigtail Camaro LT1 LS1 | eBay
Old 03-24-2014, 05:57 PM
  #388
Charlie Murphy!
iregret's Avatar
I went to my local wrecking yard and just looked around. Then I made my own harness.
https://www.performancetrucks.net/fo...8/#post5054965
[QUOTE]
The correct ones are round.
So I took apart the factory computer to add the wiring for the ISS sensor and while I had it apart I decided to put my LS1 fans in.
I removed the cover and then used a 7mm socket to remove the computer's plugs.
Pin 22 and 23 is what you add the ISS wiring to.
I didn't take a pic, but pin 42 is what you add for the LS1 fans. I did the one wire setup. If these don't work I'm going to upgrade to the 05+ e-fans and radiator. They use a 2 pin setup. It's a bit better than my setup tapping the A/C signal.
So I went ahead and soldered the ISS wiring up. Be sure you twist the wires. I shrink wrapped the wires.
I hid the wiring and loom along the frame rail out of the way.
/QUOTE]
Old 03-24-2014, 10:30 PM
  #389
sicvic01's Avatar
Thanks
Old 04-03-2014, 11:20 AM
  #390
nickleahy23's Avatar
Anyone got a number or link to buying the 2 pins that go into the connector at the computer? Having trouble finding them for the sensor wire. Thanks.
Quick Reply: ECSB 4WD 4l60E to 4l80E
