ECSB 4WD 4l60E to 4l80E
#386
#387
#388
Charlie Murphy!
I went to my local wrecking yard and just looked around. Then I made my own harness.
https://www.performancetrucks.net/fo...8/#post5054965
[QUOTE]
The correct ones are round.
So I took apart the factory computer to add the wiring for the ISS sensor and while I had it apart I decided to put my LS1 fans in.
I removed the cover and then used a 7mm socket to remove the computer's plugs.
Pin 22 and 23 is what you add the ISS wiring to.
I didn't take a pic, but pin 42 is what you add for the LS1 fans. I did the one wire setup. If these don't work I'm going to upgrade to the 05+ e-fans and radiator. They use a 2 pin setup. It's a bit better than my setup tapping the A/C signal.
So I went ahead and soldered the ISS wiring up. Be sure you twist the wires. I shrink wrapped the wires.
I hid the wiring and loom along the frame rail out of the way.
/QUOTE]
[QUOTE]
/QUOTE]
#389
