ECSB 4WD 4l60E to 4l80E
#421
nice thread. Thank you for taking the time to write this. Quick qs.
1. I will be swapping a ls with 4l80e as well but from a 92, so it is from 700r4. I got the whole trans with transfer case from the 4l80. What else do i need if i plan to use the 4l80e transfer case? DO i need to change the yoke as well?
2. I heard that some people use dirty dingo adapter and it is adjustable that you can actually utilize the stock driveshaft. How reliable is that info?
3.How hard is it to modify the crossmember?
#425
I am NOT a good welder so this was by design for me! Harbor Freight $99 welder, yo. If you have the $$, get the super nice custom one sold here. Its ******* ****!
#426
Can someone double check this write up? It's the one i used before saw this one. It's similiar but is different, atleast I think..
4L60E to 4L80E Conversion
#428
Anyone know the part number for shaft and bearings for np246 autotrac ? I've seen multiple suggestions while searching.
Installed the transfer case input shaft today..... yeah I wish it was so easy. Cost 113.59 shipped. Seems all transmission and drive line companies are on the west coast.
Attachment 140085
Came with this extra bearing. Guess I'll figure out where it goes when I tear down the transfer case.
Edit: Found it. Input Gear pilot bearing.
Attachment 140086
Attachment 140085
Attachment 140086
#429
Already have a few un-used pins in the ECM, and the wires run to the rear Bank one O2 sensor, which ends pretty nearby the side of transm,ission. Probabley could just relocate those pins at ECM to the VSS position, and splice on a VSS connector down at end formerly used at O2 sensor .
4.8 truckin
02-16-2013 04:02 PM
