everyone with afternarket wheels
if you have aftermarket wheels you need to have them balanced with the stick on weights. the old school weights will not cut it. I was in a car accident a while back and had to have three rims replaced and the body shop had joe-blow mount the tires and used the old school hammer on weights and it rode like ****. I took my truck to discount tires where I had purchased my tires and they laughed at me. They re-baleanced my tires at no charge and explained to me with the large rims you have to use the stick on weights and they had a name for the type of balancing but I do not recall.
ok cool, i didnt know that. i'll take the wheels off tomorrow night after my bio test and check for the washers, i just had my front ones turned so i doubt that they will be on but i'll have to check the back ones. i'm pretty darn sure that the vibration is coming from the rear axle for me. if the washers don't fix it i'll go back and rebalance my tires.
I don't know about the OP but my wheels are one off billet specialties - 8x18 in front and i think 10x18 in the back.
Were those static or dynamic balanced? Static means you put weight on the inside of the wheel more of less. It only balances the tire on to correct the out of balance condition of the entire tire. Dynamic balancing will correct for an out of balance on the outside and the back side of the tire. Mine were static balanced when I first got them. One was off 6 1/2 ounces and they haven't been balanced again in the 5 years I've had them and I have zero vibrations.
Another thing is that the wheels could still be off balance, 1- a weight fell off 2- wasnt balanced properly just some thoughts..
+1 on the dynamic balance. I had this done on my truck and it's as smooth as a caddy on the highway now. Also you might want to check your inner tie rods. For some reason they wear out quickly on the newer trucks, especially trucks with oversized wheels. I changed mine and it made a pretty big difference.
my wheels were cut just for my truck by billet specialties. there is not other set like them in the world. do you think it's even possible that they are lug centric? i'm at school right now so i don't have the tools to check. Would they make a set that's not hub centric if it's for a specific vehicle? if they did i can't believe it... i paid about four grand for these wheels.
