everyone with axle shims....
#41
--Pulled from the DJM page--
"Pinion shims are most commonly used for hangers and shackles on full size trucks (Chevy, Ford and Dodge)."
They don't give an example for just shackles.
#42
When using just shackles "only", it will thrust the front nose of the diff downward. This leading to what this thread is all about. Therefore, the shims would need to be placed in from the rear (fat side towards rear).
Jim
#44
another amazing piece from yours truely
I don't know why this is difficult for you guys to understand, it's basic geometry...
That's what drop shackles AND drop hangers do to the pinion angle. The differential isn't rotated like it is with drop shackles ONLY, it's just raised up which puts the pinion at a different angle than stock. With hangers and shackles, the front of the differential needs to be rotated down to acheive the correct pinion angle.
****Again, I'm no expert, but it's basic fuggin' geometry
#45
its only difficult because some peopel think one thing and others think another ha ha thanks for the time spent on your picture though
#46
I'm telling you the way it is. Did you install your shackles?
#48
http://www.carcraft.com/howto/91758/
"According to Bickel, a ladder-bar suspension normally requires ˝ degree of pinion angle, a four-link requires 1-2˝ degrees, and a leaf-spring suspension requires up to 6 to 7 degrees. In all examples, we’re talking about negative pinion angle, i.e., the pinion is nose-down in relation to the driveshaft"
#49
Originally Posted by agreif
Hellllo! Ok, I just got it. I guess my assumption is what is making me think about it incorrectly. I thought the shackle wouldn't change the angle of the pinion, but instead just "move" the diff closer to the bed, slightly changing the angle of the driveshaft relative to the diff pinion angle. In reality you guys are saying it tips the pinion downward. So I actually need to actually point my pinion upward at an even greater angle than my driveshaft? This seems to counteract what I'm reading here. Maybe my pinion was off to begin with? I'm getting the feeling the only way I'm going to be able to confirm all this is to put the stockers back on and see what it was then.
FORGET ABOUT THE ANGLE!!!
The differential is rotated as well as moved closer to the bed - since the drop shackles relocate only the REAR of the leaf spring(causing the diff rotation). You have to rotate the differential back the way if came if you want to solve anything - regardless of what the angle is, was or will be!!
