Fbody 60e in a silvy?
it will work, the only thing you need to swap out is the shifter lever shaft. f bodies have a short shifter lever shaft and trucks have a longer one because the trucks have the safety neutral switch installed there and f bodies don't
I have done the swap and other than the shift arm its a direct bolt in. I used the converter from the f-body as well. The truck trans pan is deeper and holds a little more fluid, so I would suggest you swap those also.
dantheman1540
02-24-2016 09:56 PM
mitchellmade
09-27-2015 08:25 PM
