Finally!!! Hell yeah
I wouldnt recommend a 4L60E with a trans brake in these trucks, the weight of the truck for the transmission to move is already asking a lot, I would recommend upgrading to a 4L80E if you are really dead set on a trans brake.
It stalls up to the stall speed on the brake which can be higher than you can foot brake a converter.
NO
there have been guys that have used the transbrake 4L60E but I havn't seen any that use them in the trucks. I say its a ticking timebomb to ask an already weak transmission to slam into first gear and try to sling 4500ish# out of the hole.
11 Second Truck Club
67SS509 has one.
don't know if he's used it yet.
mods:
2002 Silverado scsb 2wd- LS7-427 cu.in. 12.5cr, ETP heads w/2.20" ti valves, Jesel shaft rockers (1.8), CompCam 242/246 .642/.649 112LSA+2, Kook's 1-7/8" headers, Magnaflow X-pipe, 44lb/hr injectors, Yank3600, FLT/5+ 4L65E w/Rossler transbrake, 14bolt w/4.11, eaton, CalTracs, Denny's driveshaft
mods:
