Finish Line Transmissions (FLT) Big Sale With New Policies
We have decided it is time for a new sale and also a bit of change here at FLT. First being the sale. Here is a link to the sale. https://ls1tech.com/forums/showthrea...9#post10009849 We will be offering a 10% off on all new transmissions purchased during this sale. This will include all new transmissions. 4l60e, 4l80e, th400, th350, 700r4, power glide, and manual transmissions. This will only apply to all orders received after 8-28-08. Core returns do apply and must be returned within 30days. We reserve the right to keep a credit card on file for this time period. If you do not return our core or are not in contact with us, we will charge your card for our core and the shipping container. In addition to this sale we have decided that we at FLT will be picking the shipping for the return of the core. This is for continental U.S. only!! This is a new policy that goes into effect 9-1-08. You will only be charged for the shipment for your new transmission to you and we will be paying for the return shipping back to us of the core. All transmissions are shipped truck freight in one of our secured shipping containers. All transmissions are shipped complete and are tested on our in house Axiline Transmission Dyno. See pictures below.
Here is our secured shipping container. This what you can expect to see when your new transmission arrives.
![](http://i110.photobucket.com/albums/n97/Vinceflt/shipping%20containers/IMG_4087.jpg)
![](http://i110.photobucket.com/albums/n97/Vinceflt/shipping%20containers/IMG_4091.jpg)
![](http://i110.photobucket.com/albums/n97/Vinceflt/shipping%20containers/IMG_4089.jpg)
I would like to show you what makes FLT one of the best on the market. We put more in our transmissions then most do and spend money were others save it for themselves. There is no cutting corners when it comes to our customers. You deserve it and it is that simple.
1. All transmissions come Dyno tested. Here is the real world photo of the machine we use. This insures us that when you get them they work. No excuses. 100% satisfaction guarantee. To see some videos click on the link. https://ls1tech.com/forums/showthrea...276&highlight=
![](http://i110.photobucket.com/albums/n97/Vinceflt/IMG_1468.jpg)
2. All units come complete as a bolt in application. These units are shipped with a bell and tail. As you can see in this photo they are literally new. These are not painted units. These are virgin aluminum cases that we in house media blast. They look great when finished with a real new look! All you need to do is install them. No BS for the installer to do other than put it in. We feel you pay for 100% of a transmission and that is exactly what we give you.
![](http://i110.photobucket.com/albums/n97/Vinceflt/IMG_1446-2.jpg)
3. No need to swap tail housings and have to put a new bushing and seals in it. It's ready to go and already installed. Some companies do not supply you with this because it only cost them more money. We feel that all new transmissions require it and you as the customer deserve it. AWD and 4wd units come with the proper seal and gasket for your transfer case and it's adapter.
![](http://i110.photobucket.com/albums/n97/Vinceflt/IMG_1456.jpg)
4. All units come with the correct bell housing installed. Not making the installer do it. These bolts that hold this bell on can be very difficult to get out and often strip out. Once again giving you 100% of the transmission.
![](http://i110.photobucket.com/albums/n97/Vinceflt/IMG_1448.jpg)
5. All units come with the proper new cooler fittings. As you can see they are new and never reused here at FLT. Old fittings can leak and cause your new trans to fail due to lack of oil. Once again giving the installer 100% of the transmission.
![](http://i110.photobucket.com/albums/n97/Vinceflt/IMG_1453.jpg)
6. All units come with the proper linkage shafts in them. I get calls all the time from guy's that buy rebuilt units with the wrong ones installed. Their shifters do not line up properly or will not work at all.
![](http://i110.photobucket.com/albums/n97/Vinceflt/IMG_1457.jpg)
7. All units come with valve bodies that have been fully disassemble and checked for proper tolerances. It's the only way to do it in my opinion. These valve bodies come with the trans go hd-2 kit installed. Not a low budget in house kit that costs a couple dollars. Or simply a seperator plate that is drilled. We spend money on our units and give it right back to you.
![](http://i110.photobucket.com/albums/n97/Vinceflt/CopyofFLTvalvebody.jpg)
8. All units come with new solenoids and internal harnesses installed on the valve body. Old electronics could be the reason why the last trans failed. We like to eliminate the chance of failure. Once again giving you more for your money.
![](http://i110.photobucket.com/albums/n97/Vinceflt/IMG_1441.jpg)
9. All units come with new clutches and bands. In most cases units also get a new reverse input drum. This is where the band is applied for 2nd and 4th gear. Old drums can be dished and cause a band failure. Also the inside of an old drum can be worn and cause reverse engagement issues. We refuse to use worn drums.
![](http://i110.photobucket.com/albums/n97/Vinceflt/IMG_1272-1.jpg)
Picture of the new drum and the red Alto band used in level 4 units.
![](http://i110.photobucket.com/albums/n97/Vinceflt/IMG_1221-1.jpg)
Basically the same pic from above with the carbon lined band used in the level 5 build.
![](http://i110.photobucket.com/albums/n97/Vinceflt/IMG_1214-2.jpg)
10. All transmissions come with newly refreshed pumps. Surfaced machined with new internal components and new oversize pressure regulator valves. We do this to eliminate all cross leaks greatly reducing transmission failures.
![](http://i110.photobucket.com/albums/n97/Vinceflt/IMG_1151-2.jpg)
11. All units come with new upgraded FLT beast sun shells. This is not a normal beast shell in our level 4 and 5 builds. It comes with a bearing and sleeve for added quality/strength.
![](http://i110.photobucket.com/albums/n97/Vinceflt/IMG_1703.jpg)
12. All units come with new wide bushing were available. This gives your transmission added strength and support.
![](http://i110.photobucket.com/albums/n97/Vinceflt/IMG_1695.jpg)
There are many more things that we do. Take a look at our build sheets and compare them to the competition when purchasing a unit. There is a lot of marketing scams out there that make things look better then they really are. At FLT we fully go through your unit and do not cut corners in order to save us money. I personally guarantee it. We install many new parts in our units that others do not. I look at it as getting the most for your money! This is by far the best sale with the newly added return shipping policy FLT has ever offered. Please take a look at what we have to offer and give us a call. For questions FLT's phone number is 1-630-350-7776 and the email is sales@finishlinetrans.com. Here is a link to our site http://www.finishlinetrans.com/
Also all of our transmissions come with a 6 month warranty. At any point after the warranty if you ever have a problem give us a call. We have a program for you. It is what we call a freshen up special. We will need to get your unit back here to get you back on the road at a discounted price. The special is $250 labor plus parts. We can arrange the shipping for you but there will be a charge for this. Basically at our cost is what you pay. Being that these units come with so many new parts when originally sold, we go back through them as if we were going to build them. Some parts because we know the history of them can be reused. Obvious worn parts will be replaced and also as times change so do our transmissions. If there has been an update to our product it will be done when we freshen up your FLT transmission. It's that simple. Here is a link to see one of our level 4 builds.
https://ls1tech.com/forums/showthread.php?t=800809
Again all transmissions come fully Dyno tested. Here are some video's for you.
Here is a link to our sales thread in the sales section.
Thank you for taking the time to read this info and we look forward to hearing from you. Feel free to post up a comment or to ask a question. Also use the contact info above if needed. Thank you. Vince
Do you have clutches If yes can you please PM me the price I have trans go hd-2 shift kit and vette servo im looking to strengthen my transmission do you recommend any thing for what I'm doing?
single digit dreamer
steping it up!! you guys kick ***.
whats the highest hp guy you have running a 4l80e? have you done many tbrakes on the 4l80e and are there any side effects of using a tbrake like no more computer controled shifts or anything like that? how much power can you guys get 4th gear to handle?
Hunt&Fisherator
Excellent product and quality!!!
I have one of the "old" versions of the level 5 4L65E and I can't imagine it being any better than it is now. After over a year and a half of nitrous fed abuse, my trans still shifts like the day I put it in... I'm going into the world of forced induction now and have no second thoughts about running an FLT version of the 65E. All I'm going to do is a freshen-up to receive the upgrades I've missed and keep rolling.
After talking to Vince maybe a half dozen times in about 18 months he still remembered exactly who I was and even asked how I had been since getting out of the military... If you think about all the people he's talked to since me and he still remembers 'lil ole me, then I don't think much else needs to be said for their customer service...
Nobody better IMO....
We just decided to run a sale this last Thursday. As I stated above orders before the posted date are not subject to this sale. Don't feel bad it happens every time we run a sale. There is always someone that broke a week to soon or a week to late never fails.
![Bang Head](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_banghead.gif)
![Nod](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_nod.gif)
![Sad](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_sad.gif)
![The Patriot !!](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_patriot.gif)
Thanks Bill. Some of this stuff I know you guy's have seen but I know you guy's like pictures and video's. Figured it makes for a nice format for the sales threads when they are offered. Plus some guy's might be new to the forum and it lets them see what we are about! Thanks Bill. Vince
