Finished with 14 bolt swap...Vibration
Me and some buddies of mine swapped out my 10 bolt for the 9.5" 14 bolt Friday. As it turned out, I ended up needing a bastard u-joint for it to work. For those of you wanting to do this swap, I'll post the part number for it later.
Everything except for needing a different u-joint went smoothly. Now that I have it in, I'm feeling a slight vibration between 50-60mph. I don't think it would be my tires. The only thing I could think of is that there is a balance issue with my driveshaft. Either that, or something's up with this u-joint I used.
Do you guys have any ideas of what could be the issue? I'm glad it's over with. I just hope this isn't the beginning of new problems.
Originally Posted by TheLadiesMan
i got nothing for you and the vbration .
but can you give some info on the 14 bolt set up:
whats it out of-
rear brake set up-
is it 6 lug or 8 lug-
thanks
whats it out of-
rear brake set up-
thanks
Other than the slight vibration between 50-60, it feels perfect.
Originally Posted by James B.
Compare your pinion angle to the transmission output shaft angle. They need to match.
I am guessing that the U-joint you needed was a 3R (driveshaft) to 1350 (pinion) adapter joint.
I'd be interested to see how much it slows your 1/4 time by. Many people preach that it takes alot more power to spin one, Im wondering how much it has an effect on your times. Any plans for the track any time soon?
Wasnt talking about the actual weight but they say the added diameter of the ring gear blah blah blah will make a decent difference.
