Finished T56 installation ... no cruise in 5th or 6th
cruise
do you have the wiring on the t56 harnesed in to your system if so maybe the computer is set up to do cruise on an a4 and not regestering 5th & 6th gear im not for sure on this but its an idea id maybe run the pcm from a m6 ssr or have yours burned with the data
Ron
If I remember correctly, The T56 has a 17 tooth reluctor wheel and the 5 speed has a 40 something tooth wheel. I had to redo the calculations for the speedo to work but maybe there is another table to do with the speed sensor that the cruise comes off of that needs to be changed as well. Basically, thinking that is going too slow. Just an idea. I don't have my HPT with me or i'd dig through it now.
Well, mine will go into cruise in 4th and 5th even as slow as 25 mph but not in 6th. There are two switches if I remember correctly on the tranny besides the speed sensor. One is for the reverse light and the other one may be something the cruise is coming off of and it is making up or droping out when in 6th. I'll have to get under it with a voltmeter while someone else rows the gears.
5 year bitches!
Originally Posted by skyhighsami
I think it would be more of a computer thing and not the RPM because my Z28 would cruise all day with 2.73 gears and the auto and I was around 1500 or so at 70 90 mph was 2000. Please almost every Fbody stock was 3.42
The big brown truck just dropped of a new 4.56 ring and pinion today. So that should cure any rpm problems that I have. But I tend to think it is something in the computer that is not reading the new trans right. I don't have any tuning software yet, so I really don't know what is going on with that.
I do appreciate everyones input .
Thanks Ron
Thanks Ron
lycominghunter
08-15-2015 12:26 PM
KyleW707
07-29-2015 08:17 AM
