Finsihed up the 4in drop Flip Kit
Old 07-03-2013, 10:47 AM
  #21
Resident Retard
BlackGMC's Avatar
Originally Posted by 53bowtie
That is exactly the stance I would like mine to have eventually. Did you use axle shims or did you weld new perches? If axle shims, how many degrees? Thanks!
no shims, i welded on new perches
Old 07-03-2013, 11:29 AM
  #22
53bowtie's Avatar
Ok, I figured you may have. What did you end up setting it up at? I am guessing a few degrees negative?
Also, I have a reciever hitch on my truck that bolts to the bottom of the frame rail. Do you think it would be ok for the bottom two bolts to go into the side of the reciever hitch bracket as opposed to the square tubing you used? Thanks!
Old 07-03-2013, 12:04 PM
  #23
Resident Retard
BlackGMC's Avatar
Yeah that would probably be fine
GXPJAY
02-13-2022 08:15 AM
Verz
08-21-2015 06:40 PM
BlackGMC
08-18-2015 01:11 PM
121
07-16-2015 12:18 AM
Quick Reply: Finsihed up the 4in drop Flip Kit
