The First Manual Transmission Hummer H2
#21
The Clutch/starter switch will be done and that will bring back cruise control (the cruise module fits in the stock location right next to the clutch master cylinder). The goal was to get it up and running as fast as possible and do the clean up stuff later.
AS for the tuning, we just modified the existing Magnacharger tune. The truck runs very well, but I am sure it would benefit from some more tuning, which is also on the list.
#22
Cool, look forwad to the updates...
Here is a wiring digram i made using info from other posts on here, maybe it will help or you can verify if its right when you do the wiring...
https://www.performancetrucks.net/fo...d.php?t=395919
#24
Originally Posted by rao
Thanks for the info; I have the wiring down; I just need to get my hands back on the truck for long enough to do the work
thanks!
#29
Originally Posted by Lord Aries
Hows the h2 doing? Did you guys do they trans wiring yet?
#30
Originally Posted by 4.8T
i thought those came stock with a push button e-locker from eaton?
i think the transfer case push butons had to be in 4lo for it to be alowed to lock up.
