Flexplate fitment issue...
Hey guys, have a 2005 lq4 with mated 4l80e. Bought an aftermarket TQ converter with the LS 3 bolt pattern, and then bought a Yank LS SFI flexplate to match it up. Only thing is that it doesn't come with a spacer and I am assuming it needs one since otherwise the bolts going to the crank are too long. Can I reuse the spacer off the stock flexplate or do I need shorter flexplate bolts? Anyone know?
Currently the ARP bolts I have are .880 under head length, but this makes them about .200 too long.
https://www.circledspecialties.com/p...ank-bolts.aspx
thats the flexplate to crank bolts i used on my 5.3 when i installed my circled flexplate prior to trans swap ... might help you out
After I installed the first bolt it felt as if it was bottoming out before being totally screwed in, but instead it was resistance I was feeling all along. After re-tightening the bolt it screwed all the way with no problem. It was no wonder why I couldn't find a shorter set of bolts! lol Thanks guys!
lukn4trbl355
10-21-2015 11:19 PM
69z-28
09-21-2015 07:31 AM
Tim94gt
23
09-18-2015 04:51 PM
