flip kits
I have heard of people actually having the axle saddle that comes with the flip kits colapse or the welds break. I like the weld on spring perch idea better. Then you can get the pinion angle where ya need it and weld it on place.
Exactly
I'm using the Calvert bottom plates and getting the pinion angle right with the weld-on perches. I'm just getting all my ducks in a row for this little project. The front will be a 3" spindle and some trimmed V6 coils to get the ride height right.
is the 10 bolt housing 3" in diameter? i'm thinking of buying a set too as i'm doing a flip kit next weekend.
this is the one that TXsilvy posted above. this should work fine, right?
http://www.summitracing.com/parts/SUM-720025/
http://www.summitracing.com/parts/DCC-4120074/ $1 cheaper..
My truck is not notched yet (helper bags) but I will be making a notch shortly when I get an opening in the shop.
i think its time for me to lower my truck and u did say you could re-use the stock u-bolts ??? im probably goin to cut the front springs 1/2 a coil or so, i already have spindle up front.
also., the perches from summit are 10 each, the ones from jegs are 13 for the pair...... it says sold in pairs.... so i think, correct me if im wrong
