flip kits
Old 04-06-2010, 10:14 PM
1BADAZZSS's Avatar
I have heard of people actually having the axle saddle that comes with the flip kits colapse or the welds break. I like the weld on spring perch idea better. Then you can get the pinion angle where ya need it and weld it on place.
Old 04-06-2010, 10:19 PM
Hunt&Fisherator
silver-mod-o's Avatar
Exactly
I'm using the Calvert bottom plates and getting the pinion angle right with the weld-on perches. I'm just getting all my ducks in a row for this little project. The front will be a 3" spindle and some trimmed V6 coils to get the ride height right.
Old 04-07-2010, 11:16 AM
TXsilverado's Avatar
13 bux on summit racing. this is the route im going to replace my DJM flip kit.
Old 04-08-2010, 10:45 AM
KevinF56's Avatar
is the 10 bolt housing 3" in diameter? i'm thinking of buying a set too as i'm doing a flip kit next weekend.
this is the one that TXsilvy posted above. this should work fine, right?
http://www.summitracing.com/parts/SUM-720025/
Old 04-08-2010, 10:49 AM
yep. 3" is correct.
Old 04-08-2010, 12:38 PM
and whatever yall do, stay away from DJM notches.
Old 04-08-2010, 01:01 PM
gtosilverado's Avatar
lol yep, they are a piece of junk. just a flat plate with holes. beltech and McGaughys are better.... Zach what did u use for your c-notch ?? and do u have pics ?
Old 04-08-2010, 04:00 PM
Camaro Zach's Avatar
if you run those make sure that your spring is wider than those perches. Unless you box the ends the flat plate top of those tends to shear away from the sides where it is bent.
http://www.summitracing.com/parts/DCC-4120074/ $1 cheaper..
My truck is not notched yet (helper bags) but I will be making a notch shortly when I get an opening in the shop.
Old 04-08-2010, 05:17 PM
i think its time for me to lower my truck and u did say you could re-use the stock u-bolts ??? im probably goin to cut the front springs 1/2 a coil or so, i already have spindle up front.
also., the perches from summit are 10 each, the ones from jegs are 13 for the pair...... it says sold in pairs.... so i think, correct me if im wrong
Old 04-08-2010, 05:24 PM
No you need round ubolts, plus you shouldn't reuse ubolts anyway. They stretch
Quick Reply: flip kits
