FLP 4L65e Level 5 is in
Originally Posted by FLT
Let me know if you need a tee for the booster hose, it should have came with the trans? Also make sure you install a blower bypass check valve for the boosted application as well in the vacuum line. I have those at the shop as well.
Chuck
Finish Line Transmission
Chuck
Thanks,
Randy
FormerVendor
Originally Posted by ranwalk
I bought the trans from a friend. I will need the t and the bypass check valve. I didnt know I needed the check valve. What happens if I run it without it? Should I leave the vacumn line undone until I get it?
Thanks,
Randy
Thanks,
Randy
Don't run the trans without it, You can damage the trans if boost gets into the vacuum signal, I don't recommend running the trans without the line connected either because your running the trans at max line pressure at all times which not good either. If you need both pieces you can call me at the shop 630-350-7776 and I'll send them to you on Monday. I also would recommend that you buy a piece of 1/4 inch brake line to make the vacuum line out of, It works better than rubber hose IMO.
Chuck
Randy,
Chuck
Chuck
Vacumn t and check valve will be here tuesday thanks to Chuck
Its nice to see someone build a hell of a product
and provide the CS to match
I love my level 5
FormerVendor
The transmission will shift softer and smooth under regular driving, but when you get on it, it shifts fast and firm
Chuck
FLT
