FLT L7 Install / Tru Cool 40K / Bud Hayes3 rocks!
#45
Glad to see you got the 45° hose ends. good choice.
Hey, I thought I told you NPSM, not NPT. I would have used these. Or preferably, ones with an O-ring seal
It's what guy at the fitting/ hydraulic store recommended. I said what bout O-ring? He said not needed. Andy said I shoulda told u I was goin AN so u coulda installed them instead.
![Bang Head](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_banghead.gif)
Vince, is that index washer, for lack of a better term, the only diff.?
skolman91, ya I love how MI road salt just uglies up underneath & leaves a rusty frame.
HoveyBayou, no donut vids. No vid cam. ...Yet!
![Grin](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_grin.gif)
#48
No, I've just had my hands in a lot of different things. Before becoming a welding inspector, I ran the equipment department for a construction company and of course my early background was an instrument fitter. In my spare time I would build off-shore race motors and good faith re-builds on hurt crate motors for a local GM dealer when I lived in Norcal, which just about all were big-blocks of course.
#49
FormerVendor
What I normally do is us a bit of anaerobic sealer on the threads. Then tighten the fitting up holding the washer on center as best as I can. When the shoulder of the fitting comes in contact with the washer and the case I now have double seal. Works well for what it is.
I'll have to get my hands on a set with the orings to see if I like those better. They use the same concept for the rear cooler fitting on a 97 and later 4l80e. The only difference is the pressure on that fitting is directed right into the center support. Not sure how this will work when the actual hole the threads go into see's pressure.
#50
No it is another form of seal for the fitting to case. I have never seen an oring for these so that's new to me. The brass washer is a bit funky because it kind of floats around before you totally tighten the fitting up. Does not fit tight on the threads as one would think it should I guess is what I'm saying.
No leaks.
![Nod](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_nod.gif)
BTW, I may've already mentioned it, but guy @ hydraulic / fluid systems store showed me the blue fitting I went w/. after I showed him that Russell 1 you mentioned.
EDIT: Permatex 51813 = Loctite 518, or is there another 1 you use that dries in absence of o2?
Loctite 37394 is only $8 from Summit. Permatex 51031 Anaerobic High Temp Flange Sealant 1.69 fl. oz. 50 ml is a bit pricey ~$23. Even more $$ is Loctite 574 Anaerobic Sealant @ $25.
![EEK !!](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_eek2.gif)
So which 1 do u recommend? For other PT members since mine is lookin the way I want it too now it's tight - DRY.
