Flywheel to converter gap with 6.0 Swap
Old 06-17-2007, 05:31 PM
agreif's Avatar
Default Flywheel to converter gap with 6.0 Swap
Guys,
Putting the engine and tranny back together and noticed I have ~3/16 gap between the flywheel and converter without the two bolted up. I took the flywheel fom my 4.8 and swapped it into this 07 LQ4. I took a look at the flywheel that came on the LQ4 and noticed it had a 3/8 "spacer" on the engine side, so I'm fairly sure that would not have worked with mt 4L60E. I just want to make sure that gap is ok before I go and close the gap by bolting that up.
Thanks,
Andrew
Old 06-17-2007, 07:09 PM
quicksilverado's Avatar
I had the same problem. Just used a couple of washers to fill the space. Never had any trouble in 60k plus miles.
Old 06-17-2007, 11:00 PM
Colby 04's Avatar
sounds normal to me...
check out Yanks install guide on www.converter.cc
Old 06-17-2007, 11:02 PM
pbraxton's Avatar
tighten it up! don't use any washers.
Old 06-17-2007, 11:19 PM
Per Yanks website, gap should be no more than 5/16 of an inch, use spacers as needed.
Old 06-17-2007, 11:21 PM
Colby 04's Avatar
ok...3/16 sounds like less than 5/16 to me
Old 06-17-2007, 11:22 PM
pbraxton's Avatar
would you like to borrow my tape measure?
Old 06-17-2007, 11:23 PM
Colby 04's Avatar
yes please...mine is metric...
Old 06-18-2007, 12:07 AM
ramsey rider's Avatar
hey buddy as you know i just did the same swap .i ran into the same delemma ,come to find out ,just bolt it up its fine ,send it mines fine and i did research it after the fact though lol.
Old 06-18-2007, 12:24 AM
TXsilverado's Avatar
suck the converter on up there with the bolts. its normal.
Quick Reply: Flywheel to converter gap with 6.0 Swap
