flywheel question
OK this is what I have... 1966 chevy c10 / 350 vortec / t-56 mechanical clutch..... I need to know if the flywheel on a LS1 is the same bolt pattern of a Vortec motor. If anyone know pleae let me know... Thanks alot.
DR
DR
Still???? I klinda need to know...If anyone has a flywheel for a vortec motor if you can give the the measurements from bolt hole to bolt hole (centers). Thanks alot.
DR
DR
The two motor do not use the same flywheel, the old style small block require a balance flywheel unless you have an internally balance motor. Even if your motor is internally balance you will still need a different flywheel.
carid
09-10-2015 09:07 AM
