Front axle (8.25") carrier bearings
Old 04-12-2011, 09:03 PM
KAC1023's Avatar
I found this thread when google'n our IFS diff's, also came across a place called drivetrain.com that offers bearings using Timken Bearings that I've heard people talking good about
http://www.drivetrain.com/parts_cata...ial_parts.html
http://www.truckmodcentral.com/forum...ad.php?t=13813
-In the thread you can see there are metal locking tabs to prevent the carrier bearing sleeve from backing out
Last edited by KAC1023; 04-12-2011 at 09:05 PM. Reason: forgot to say how the thread shows the locking tabs
Old 04-14-2011, 05:04 PM
sintered's Avatar
Timken bearings are the ones to have from what i've read. It's also imperative to get the updated spanner nut locking tabs from the 07-newer models. Either way, the dang things are still prone to problems.
I still can't find any info on the web about mechanically locking the spanner nuts into place. I looked at a spare diff and can kinda visualize drilling a hole through the case, welding in a nut to reinforce the hole and provide a passage to installing a locking bolt to hold the spanner still. You could jimmy-rig it by getting everything installed right then spot welding the spanner to the case. Would have to throw it away if it never needed a rebuild again though.
Old 04-14-2011, 06:25 PM
Senior Member
Country Boy's Avatar
Whats different with the locks from the 07+?
Old 04-14-2011, 06:52 PM
KAC1023's Avatar
I'd like to know, because my drivers side bearing is shot or "loose" if I can fix or replace it w/o removing the whole diff unit? In the rebuild thread I posted it seems as if I got a slide hammer I could pull the axle and seal. Does the bearing remove from the "outside"? If thats the case I will fix mine quickly this way with one bearing, one racer, one seal and I guess one of these "updated" locking tabs?
Old 04-15-2011, 08:38 AM
PT's Slowest Truck
budhayes3's Avatar
Pretty sure that you have to crack the front diff open to replace the carrier bearings, just like on a rear differential, but I've never had one apart so I can't say for sure.
I'd like to see pics of the 07+ retainer plate and the previous one side by side, if anybody buys the new one and rebuilds their unit
5.3Okasai
03-09-2022 01:07 PM
gnasty1521
35
11-19-2015 11:42 PM
nickpc82
11-02-2015 02:49 PM
vipergtrdj
08-06-2015 10:19 PM
Ketis
07-23-2015 12:37 PM
Quick Reply: Front axle (8.25") carrier bearings
