Front coil over installed
ill try and get some pics this evening if i dont work over! its not as low in the front as before. got your pm ill send you some info this evening
no, the T-Bar mounts up top instead of below the lower control arm. simple install just drill out the threads of the nut that the stock mounts bolted to and install new bolts! the nut will help support the longer bolts, i used lock nuts to achor the bolt going through the T_bar
800 lb. spring rate, if i need 850's or 900's its not out the question, i'll see how these work out first
the back is 4 linked yes theyre relocated.
Nice work on the coil overs skeet i might get with u for a few questions when we start putting my truck back together ive just bought a pro charger and a whole lot of other goods for my ext-cab..
BRET
BRET
