Front diff whine under cruise and decel, not on accel
having a front diff whine on my AWD denali from the day i bought it used and seems to be getting worse with the cold weather. i know it is the front diff because i did have the front drive shaft out of the truck to dyno it and on the road there was absolutly no noise.
it only whines under cruise past 30mph or so a decel, it has never bothered me before but now its getting loud enough to hear it over where i would normaly have the radio now.
how many people have had problems with the front diffs on these AWD trucks??
who has one for sale??
Fastest D1 Procharged Truck
my guess is its probably the bearing were the front half shafts bolt up to i had that problem with my old truck when it was in 4WD PITA to fix have to pull the front diff to get in there
does not sound like a bearing noise, bearing noises are consistant with speed, this is a howl/whine and varies, and with the drive shaft from the t-case to the front diff was out of the truck, it made no noise what so ever.
also no leaks either
im leaning towards that but i want to see who else maybe had a problem like this, id rather not buy a front diff assembly if i dont have to, this is my first AWD truck so i just want to make sure.
if i get some time ill get a set of chassis ears on it and really see where the noise is from but now the weather is shitty around here
I have an AWD Escalade and have had the same front noise problem for the last 60K miles. It is usually louder in the winter and becomes quieter when coasting and loudest when in constant throttle. At higher speeds it is less noticeable. I always thought it was just drive train noise. When I checked the wheel bearings and I did not find anything wrong.
PT's Slowest Truck
I'm having noise from my front diff that gets worse in 4wd. I can hear it also in 2wd, but it's not as prominent. In 4wd it seems to make more noise while driving slowly with my foot on the gas, but I also hear it on decel. Can't seem to hear it while cruising though, but I have alot of other noises from the exhaust and air intake that may cancel it out. I found alot of metal on the drain plug when I changed the fluid last fall...I was investigating it this year when my trans blew and became my first truck priority. I listened with a stethoscope and the truck running in the air in 4wd. I heard loud noise from the l/s carrier bearing area and the pinion bearing area, but the r/s and middle was quiet.
I had a whine in my front with decel and light cruise. Recently changed the front wheel bearings, common issue and no more whine. I had the wheel off doing brakes and just spun the front axle and could hear the bearings grinding. Also had some play in it. Only 75k miles on the truck.
I also have a low mile (approx 45k miles) front diff with 3:73's I'd let go.
