front end "clunk"/noise
I have an intermittent "clunking" noise in my front end. I have checked (and greased) all ball joints (all aftermarket units that can be greased) and they show no signs of play (couldn't force any wobble).
I have been reading for some time about the intermediate shafts being bad and also noticed a post about the lower steering gear bearings going bad at times.
This intermediate shaft "issue" stems from the steering column being "collapsible" right? With that in mind, COULD a person remove the intermediate shaft and weld the two sections (inner and outer) together thus making a solid unit that WOULD NOT move AT ALL (yes I understand this prevents collapsing of the column, just bare with me)?
In another post, someone put up a link to a link (summit) to a Borgeson Steering Shaft:
http://store.summitracing.com/egnsea...115+4294907434
I'm rather tempted to go "all out" if I have to replace the shaft and do it "once and for all."
Any other input?
Any other input?
If you want a quick fix, unbolt the shaft and cycle it in and out a few times. This will stir the grease up, and the clunk should go away(for a while at least) I did this 10000 miles ago, and it hasn't clunked since.
Corvette454l88
09-01-2016 01:24 AM
5.3Caprice
11-07-2015 08:56 PM
Offroadunleashed
07-20-2015 02:25 PM
