Front End Lift - 4x4
I am taking delivery of a new '06 RCSB 4x4 tomorrow. I would like to lift the front to be equal to the back height, does anyone know how to achieve this cheaply?
Could I swap out the front coils for a 3/4 ton, or 3/4 HD? Would the coils interchange? Would I screw anything up?
Don't want a sky high ride, just a little added height.
Thanks,
Keith
Thanks,
Keith
You can crank down on the torsion bars to lift it a little bit. Just make sure to have a front end alignment done whether you do that or use coils cause that'll throw out the alignment.
14 Second Truck Club
The 4WD's all have torsion bars, crank them up and it will level it out. And yes you can swap out the 3/4 ton TB's with the Half tons. Requires some work.
I need to see a blow up drawing or picture of the front suspension so I understand how the torsion bars work, especially with no springs? Can anyone help me out?
About tightening my torsion bars, how is this done? I'm assuming the tie into the fram somwhere near under the doors? Can I crank those things down myself? With a 1/2" impact, what size? How do I keep the truck level, turn the bolt equal number of turns on each side?
I'm not looking to jack it up real high, just level it out. I had the torsion bars cranked down on my '89 Pathfider and it made all the difference in the world as far as looks and leveling out goes.
Any help would be appreciated.
![Hail](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_hail.gif)
Any help would be appreciated.![Hail](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_hail.gif)
5.3Caprice
11-07-2015 08:56 PM
Offroadunleashed
07-20-2015 02:25 PM
