Front end replacement parts, is Moog the preferred brand?
Resident Retard
I am going to be replacing my entire front end suspension parts in a few weeks i was wondering if Moog was the preferred brand.
Also should i replace the inner tie rod ends?
Moooo....
Yes MOOG is the OE quality stuff. Anything not a MOOG is a lesser part. If you're replacing everything, I see no reason to pass up the inner rod ends either.
What I do recommend is cryo-treating the high stress parts like the pitman arm. I've had good luck keeping them tight longer after treatment.
Corey,
I just did my front end and found out it was cheaper to buy the whole control arm than buy each each part to replace existing parts. I used Napa part and it cheaper by $30 to $40 depending. Side not i had a hard time finding the right bushing for the lower controller arms and ball joints in the lower control arm a bitch to take out.
mzoomora
01-03-2016 07:06 AM
Offroadunleashed
07-20-2015 02:25 PM
