Which front/rear Diffs are on my truck?
2007 OBS Sierra Classic 1500
5.3 motor.
The rear is a 10 bolt. Im asking because I want to change out the fluid, just dont know how much to buy.
Thank you.
5.3 motor.
Thank you.
Where's the Beef?
the code G80 means your rear diff has an Eaton "G80" Limited Slip Differential which will explode immediately if you use the wrong fluid. It's not very strong.
If your not buying a ring and gear it doesn't really matter what size the front is. You just need to make sure you have the proper fluid.
Run Synthetic in the rear since it has a g80 and run normal 80/85/90 in the front is what I'd do.
11 Second Hall Moniter
^^^hilarious^^^
You should use synthetic in the rear diff, no matter what. Most need about 2.6 qts. GM actually recommends synthetic in the front differential if you are in a cold climate. It will use just under 2 qts.
If you are not in a cold climate, you could use any GL-5 rated 80w-90 gear oil in the front diff.
