Front Suspension question
Old 05-12-2010, 05:02 PM
04Burban's Avatar
Default Front Suspension question
I have an 04 Suburban and an 03 SSS. Both are riding on the bump stops in the front. They both have brand new shocks on them, but i'm sure this is why it's not riding as smooth as it used to. How do I fix this problem?
Old 05-12-2010, 05:28 PM
Dewey's Avatar
you probably bought the wrong shocks, or if you took it to a shop they may have installed the wrong ones. it could also be that they're defective.
Old 05-12-2010, 05:33 PM
04Burban's Avatar
this happened during the last suspension setup. it was fine and worked it's way down. The SS was on stock and the 'Burban had Bilstein. That's why I was thinking it was something else.
Old 05-12-2010, 08:30 PM
traveling mod
andrew383's Avatar
Crank the torsion bars up alittle on the silvy.....Sounds like the springs are sagging on the burb..
Old 05-12-2010, 09:10 PM
Jordan927's Avatar
Sawsall
Old 05-13-2010, 02:59 PM
11 Second Hall Moniter
AKlowriderZ71's Avatar
The bumpstop is a working part of the suspension, and on most trucks & SUV's in stock form, they do contact the lower control arm at static height. Your concern is likely caused by something else. Perhaps your wheel/tire combo is heavier than stock?
Old 05-13-2010, 03:02 PM
Wearin' da big hat
00ChevyScott's Avatar
Ya mine has always been veryyyy close to the bump stops if not touching them on the front. I always thought it was weird too.
Dewey's Avatar
assuming the sig pic is current, then the ss is on factory wheels. the suburban i'm not sure about.
Old 05-13-2010, 10:31 PM
PT's Slowest Truck
budhayes3's Avatar
As mentioned the bump stops are factored in to the spring rate of the front suspension and should be just touching the lower control arms at rest. What about the shocks, did you go with factory replacements or something else? Is it possible that the new shocks are stiffer than the old ones?
Old 06-25-2010, 06:49 PM
04Burban's Avatar
I hooked up the torsion bars on both of them and it made a world of difference. Especially after my alignment. Thanks for all ya'lls help
Quick Reply: Front Suspension question
