Front uneven after drop
Old 06-05-2007 | 06:30 AM
2k5Squirrel's Avatar
14 Second Truck Club
Default Front uneven after drop
did lowering coils on the front this weekend. driver's side sits about 1/2 an inch lower. which side didn't seat properly?
here are some pics, don't know if y'all can tell or not
https://www.performancetrucks.net/fo...d.php?t=394217
Old 06-05-2007 | 08:07 AM
BlackLM7's Avatar
Sounds like you have the "Chevy lean". You probably always had it except now it's more obvious because you have less fender gap. Go measure the rear now. I bet the driver's side rear is slightly lower than the passenger side.
Old 06-05-2007 | 10:04 AM
i'll have to do that when i get home. i know about the "lean" but i figured new coils up front would correct that?
Old 06-05-2007 | 10:08 AM
Raffman's Avatar
I did air bags and tubular A arms and still had the lean.... I run more psi in the left front to level it out and moved the battery to inside the box on pass side.
You will prob have to go with a coil spring spacer on the left front.
Old 06-05-2007 | 12:21 PM
Diablo666's Avatar
stylin concepts sells the spacer to fix the unfamous chevy lean.
Old 06-05-2007 | 01:58 PM
looking at you sig and thought you would get a kick out of the sticker i had on my old 2WD ECSB
Old 06-07-2007 | 12:56 AM
RedHot04's Avatar
yep that's common, I had it then & still got it now. That 1/2" tends to eat up my left tire if there's a dip in the road or coming in my driveway! If I had some skinnies up front then I wouldn't mind as much.
Old 06-07-2007 | 01:01 AM
RandomHero's Avatar
LOL you guys think you have it bad. My situation doesn't even make sense. My passenger side sits lower than my drivers side. Here's the deal though....my front drivers side tire is the only one that rubs.
I sit at:
Front left-31.5
Front right-31
Right rear-28.5
Left rear-29
and yes my front is 2" higher than the back(I'm running a 2.5/7 drop until I put my coils on)
Old 06-07-2007 | 02:40 AM
RedHot04's Avatar
you got reverse Chevy lean w/ a twist! BTW I know but what converter are you planning on buying?
Old 06-07-2007 | 02:41 AM
RandomHero's Avatar
I already have a ss3200 it's just sitting in my room waiting to go in. I need to get my tranny built first.
maxspeed05V
11-11-2015 05:20 PM
vmaxpro
08-10-2015 08:25 AM
GMCSIERRA5.3
08-07-2015 02:50 AM
Ammadien
07-22-2015 09:50 PM
