Front wheel bearing prices...
Mr. Obvious
Originally Posted by FastCrewCab4x4
The tapered part with the rollers and cage on it is the inner race. the part that they fit into is the outer race or "cup" when you buy the bearing be sure to get the cup, then with it in your hand you'll see how all the parts go together.
Oh, So they have Ball bearings instead of tapered rollers. I haven't changed them on my newer truck. but cars and my old S10 had tapered bearings. If they are self contained ball bearings then it will be pretty easy, you won't even need to grease them..
Mr. Obvious
I'd like to see how it's done as well, if only to get a better picture in my head of the process. I'm sure it's pretty straightforward, but every little bit helps!
11 Second Truck Club
the house brand at O'Reilly is $150 as stated above and the National brand is $190...
Rock Auto lists the BCA/National brand for $141.99...you MAY be able to get O'Reilly to match Rock Auto if you print it out and take it in because O'Reilly now offers online buying as well, but with free ground shipping to your door on any purchase over $75. Even if they met you half way on price, it may be worth getting the part same day.
I just recently paid $150 ea. for mine from NAPA.
A brief overview on the install for a 99+ nbs 2wd:
Raise and support vehicle, remove wheel/tire, remove brake caliper and mounting bracket, remove brake rotor, remove the 3 bolts from the back of the bearing holding it to the spindle, disconnect the wheel speed sensor/abs sensor harness, tap the bearing unit out. Reverse for assembly.
