frt drive shaft & transfer case issue
Recently I started to notice a noise coming from under the truck in the transfer case area. Af first I thought the noise was from the rear driveshaft, so I bitched when I bought the truck and they replaced the rear u-joints & slip-yoke putting in the newer style nickel plated one. This cured some of the issues for a while, then a similar noise returned. This time I'm pretty sure its from the front yoke on the transfer case, if i grab the front drive shaft I can move it up and down & side to side pretty easy, now I know it should have some play but this is enough play that I can mimick the same noise. So has anyone had this issue before? Just wondering if this is something that is common?
Thanks
J
Thanks
J
MileHighSierra
07-23-2015 12:19 AM
04BlackGmc
07-16-2015 05:10 PM
Gadgetized
07-07-2015 05:40 PM
