full specs of a 4L65e tranny part#s and etc...
12 Second Club
Here is what goes into a JAG '65
INCLUDES THE FOLLOWING New STOCK PARTS x
Borg/Warner Low Roller Clutch
New Bushings
GM Internal Wiring Harness
GM Solenoids & Switches
Gm 5 Pinion Front & Rear Planet Assemblies
Seals, Gaskets, Filter
HIGH PERFORMANCE ADDITIONS
High Performance Output Pump Slide Spring
Borg/Warner 29 Element Forward Sprag
Steelx.500 Boost valve
Wide Red Band, Performance Lining
"Z" Pack- 15 Element 3-4 Clutches High Performance Application
"Beast" Heavy Duty Shell w/ Bearings & Wide Bushing in Reaction Gear*
HP Forward & Overun Clutches
Borg Warner Low Reverse Clutches
TransGo HD-2 Shift Kit
Corvette Servo
Metal(Aluminum) Accumulator Piston
TransGo Seperator Plate
Hardened Pump Rings
Sonnax 4th Gear "Super Hold" Dual Servo
Wide sungear bushing
OPTIONALx PARTS AVAILABLE
Hardened Stator Shaft - This is listed as an option because we have purchased "Hardened" shafts and have found that they are not any different than those already being used. However, we understand that some people may feel differently.
* "Torque Drive" Unit x(Has "Beast" Heavy Duty Shell)
New Bushings
Corvette Servo
Hardened Pump Rings
Stainless Works
09-03-2015 08:31 AM
Alvin@PCMofNC
09-03-2015 06:38 AM
