G80???
#21
It's not so much a factor of power that breaks these things, it's how much traction you've got between the tires and the road while still getting wheelspin. The more traction the more torque the mechanism has to deal with. The G80 works by spreading pressure against the end from within against carbon fiber clutches on both sides. The lockup mechanism is self-energized, meaning it gets it power from the torque it's dealing with. The mechanism that applies the pressure is like a ramp. It gets energy when there is enough slippage to fling out a centrifugal counterweight which then engages it. Until that difference in RPM between right and left is reduced enough to stop the pawl from engaging it will continue to apply torque to that ramp gear to make the clutches tighter. So, as horsepower increases, so does the forces against the housing to achieve lockup - it all works together to eventually explode them violently.
(Thank you for giving me an excuse to post some of my favorite pictures)
The difference between how the G80 and a true Limited Slip differential works is that a G80 responds to wheel slippage. The G80 only works after traction to a wheel has been lost. A Limited Slip gets tighter in proportion to the amount of torque load on it - LSDs actually PREVENT traction loss in the first place.
The G80 has absolutely no place in a performance truck. It is totally the wrong type of mechanism for the desired performance results.
#25
Ok guys, bare with me, I'm still confused as to which eaton differentials you guys are buying. Is it a limited slip or an e-locker?? dont they do the same thing except the e-locker you have to lock it first?? THANKS!!
#26
I think most people here have the limited slip eaton or auburn
if I understand the e locker correctly
some kind of electric solenoid locks it and it stays locked with the flip of a switch
#27
Who said anything about an E-locker? Those are for rock crawling or some other such low-speed nonsense. They won't even function above a certain speed.
The only Eaton product for a performance street truck is the Eaton Posi Limited Slip differential. (NOT the factory "locking" G80!)
#29
14 Second Truck Club
