G80 is being a weirdo....
Old 05-10-2006, 03:28 PM
sounds like eaton has earned a good rep
Old 05-10-2006, 03:43 PM
High on diesel fumes
thunder550's Avatar
Lots of people are happy with the Detroit Truetrac as well, there are no clutches, it's all gears. That's what I have. Truck has been down most of the time I have had it in there, but it seems to work well from the little bit I have been able to play with it.
Old 05-10-2006, 07:28 PM
Post
My G80 works like it should currently. The service manager did stress to have the G80 fluid changed at least every 30,000 miles. He said it helps prolong the life of the clutches that seem to fail in them (quite often) causing the one wheel peel.
Mine makes two black marks into the pavement equally thus so far.
I will be changing the fluid in about 5,000 more miles to see if this helps the G80 in the long run or not.
Jim
Old 05-11-2006, 06:41 AM
Hunt&Fisherator
silver-mod-o's Avatar
I guess its time for a fluid change then... I hope its not too late.
Old 05-11-2006, 12:21 PM
I have had an Eaton for 3 years and love it. In fact I just had my rear end rebuilt and put 4:10's in. The posi is still in good shape. Your other option could be a Detriot locker, but I have heard they are noisy.
Old 05-11-2006, 12:42 PM
nonnieselman's Avatar
i was told by many people that i was supposed to put the Additive in there... Ill change it this weekend to see if that will help?
What about the Eaton LSD, what fluid and a additive or no additive??
Old 05-11-2006, 12:45 PM
and yes the G-80 has 2 clutch packs in it.. one on each side.
we cut a G-80 apart a few weeks ago.. there are a bunch of parts in there. wonder if you could put a zip tie on teh fly weight to keep it from unlocking over 20mph??
Old 05-11-2006, 03:56 PM
jadaven's Avatar
Post jack....G80 on these trucks is a 30 spline correct? I'm looking to update my non-g80 to one. Cheap.
Old 05-12-2006, 06:59 AM
Hunt&Fisherator
yep its an 8.6 gear with 30 splines.... Good to see ya over here Jim
Old 05-12-2006, 06:13 PM
jadaven's Avatar
yeah, i'm prolly gonna look for a used one over the weekend. good to be here
Quick Reply: G80 is being a weirdo....
