g80 go bang!!!!! what to get
'Bulletproof' and '10-bolt' have no business in the same sentence. There is no such thing. As long as you have a 10-bolt/8.5" differential in your vehicle, you have a weak link in your drivetrain. Couple that with a 4L60E, and basically everything from your flywheel on back is running on borrowed time, especially when you start adding power and torque, and especially when you have a heavy vehicle.
That said, I would recommend the Eaton LSD and OEM/AAM gears, as some others have already said. That is what I installed a few weeks ago. The 400 lb springs in the Eaton will be fine for you - 800 lb'ers will not make your rear any stronger. Good luck.
Originally Posted by TheLadiesMan
what is all need when putting together a nice solid, near bulletproof daily driver rearend.
as i was reading around on other threads it seems like almost everyone is saying that a detroitlocker is stronger then an eaton, but here everyone is recommending an eaton. am i missing something? i will take everyone word on this and buy an eaton. my buddy PORN_1 also has an eaton in his truck and i like how it works, it just seemd like maybe i am missing something?
also my ring and pinion looks to be in great condition should i reuse them or get a new one?
wow!! you really know how to make it easier for me to sleep at night!!
what a rush!
thanks for the help
I chose the detroit locker for that ultimate in strength, but that's definetely not the path most taken.
blownerator
Originally Posted by Crash Dummy
We had the 800 lb Eaton in our 6.0 shop truck RCSB with 3.90 gears, axles, Cal Tracks, Hal shocks, 28x12.50 ET Steets 550 RWHP 11.70 and the best of all 1.52 60" times, all the time I think thar posi has seen at least a couple hundred 1/4s and its still alive. Takes a lickin and keeps on tickin!
Agreed the EATON will be more than enough for most.
isn't the detroit truetrac a limited slip? that was the one that i was looking to get, not a locker.
now how about more on what gears to get.
naked av told me to look into OEM/AAM gears does anyone else have any other sugestions?
now it is off to do some price checking
