g80 go bang!!!!! what to get
#21
Originally Posted by Naked AV
I'm in the same boat as you, probably a little worse. My truck weighs 5800 lbs without me in it, and with the Radix I am already in trouble, without smaller pulleys or more power. So believe me, I feel your pain. I'll just drive the truck until something breaks then decide what to do from there.
#22
what a rush!
Originally Posted by PORN_1
Your in the same boat, How about blown rearend, 2 blown Trans, a blown engine. Now after the 6.0l swap its the rearend again. I ripped two teeth off of my pinion and all the teeth had stress crack on them. They are precision gear and they,re only a year old. Can anyone help me out.
j/k
#24
If I blow up my rear I'm getting a 9.5" like the one in the VHO (and the new Trailblazer SS), I'm not even messing with a 8.5" again. Why would I bother? I'm not a masochist, so forget it.
As far as the tranny, when/if I blow up mine, it would be a dilemma between at 4L80 swap and an FLP L5. After seeing how Chuck treats his customers, I'd be very tempted to go the L5 4L65 route.
#25
Did I tell you I grew up in Milford? Right off Hickory Ridge Road, a stone's throw from the GM Proving Grounds....
i looked at my ring and pinion, they look to be in perfect condition, should i reuse them?
#26
upgrading the rear in yours will probably be a good idea. that's alot of weight on a 10 bolt. going to take a bit of work to have the brackets put on would be my only guess.
#27
Originally Posted by TheLadiesMan
that is like 10 mins from me and probably 10 mins from PORN_1. did you go to milford highschool? if so what year did you graduate?
I'm not a gear guy, so I can't tell you if your gears are good or not. I don't know if 'looking good' and 'being good' are the same thing. Hopefully someone else will pipe in with the correct answer.
#28
I don't really have the money for the 9.5 rearend swap, Parish said he thing it would be around $1500 and I don't have the money because I just did a 6.0l cam swap and there people with 2wd trucks putting more power to the ground then me and there using the 8.5 rearend and thats holding up.
Cha_Feel_
09-23-2015 09:06 PM
