Gear Install- How Much?
i never had my truck track tested from the 3.42's to 4.10's...i wouldnt think you would gain 3 tenths in the 1/4, maybe .3 in the 1/8 and .2 in the 1/4....dont as me where im getting the numbers from cuz im just pulling them out of no where so im probably way off so its just a complete guess
5 year bitches!
its about 150 for gear install here. if youre just swapping gears and everything else in the rear is in good shape. just swap gears and measure backlase and youll be fine. i used stock gm gears when i went from 373 to 410s. have around 600 miles on them no hauling no tight spots nothing. but if youre using another brand of gears i would recomend getting correct shims andetc
so when i buy the gears i should order shims with them?>
