gear lube?
Old 04-11-2009, 06:47 PM
Parke10's Avatar
Just finished doin mine, first time its been done and it had 46k miles on it, fluid was pretty bad. mag looked pretty clean. i used 75w-80 LS Mobil 1, it feels like it runs smoother, but thats prob all in my head.
Old 04-11-2009, 10:34 PM
PT's Slowest Truck
budhayes3's Avatar
Placebo effect But hey, if it makes you feel good, roll with it
Old 04-11-2009, 11:36 PM
Parke10's Avatar
Word..
Old 04-12-2009, 09:42 AM
black4.8's Avatar
lucas here
Old 04-12-2009, 06:45 PM
Parke10's Avatar
the stupid thing has a very slow leak and idk why, its leaking from the cover, i made sure when i had the cover off i got all the old gasket off and i even cleaned it up when brake clean.and i made sure the rearend its self was clean too, but still has a tiny lil leak, i even double checked the tightness of the bolts. looks like im gonna have to put a lil RTV or something on it.
Old 04-12-2009, 07:05 PM
Baltimore Whore
Mangled03gmc's Avatar
Lucas 80-90
Old 04-12-2009, 11:13 PM
QLF
QLF's Avatar
Use a bead of black high-temp RTV silicon all the way around the new gasket. Make sure the entire gasket surface is super smooth with no nicks or dirt. I use some Scotch-Brite to clean mine after wire-wheeling. Slowly tighten the bolts until they are hand tight, then put a 1/4 turn on them with a ratchet. Now wait about an hour or whatever the RTV says to let it set up. Then come back and tighten them to spec.
I use Royal Purple 75-140 synthetic with my Yukon's and Zexel.
Old 05-08-2009, 11:03 AM
Gixer's Avatar
if I use Mobil 1, do I need the the additive for limited slip ?
Old 05-10-2009, 10:29 AM
Avalanche2002's Avatar
No additive for the G80.
I don't have to deal with taking the cover off my 02 Avalanche as it has a drain plug on the bottom of the rear diff. I just changed mine at 59k miles last weekend. It took about an hour start to finish, cleaning up included, and about 8 ounces shy of 3 quarts of Mobil 1.
Old 05-11-2009, 11:18 AM
Gixer's Avatar
thanks for the reply, I did it Saturday and I added it anyway to be sure. im glad I did have to take off the cover, the magnet was full. 150k and 1st time.
Quick Reply: gear lube?
