gear swap Q's
gear swap Q's
im going to change my factory crap 3.23's and was looking at 3.73's or 4.10's. my truck is a DD so which is more streetable, what about after 20's? and i have the factory diff locker, is there anything i need to change to keep this or something else i should buy other than the gears itself? thanks
FormerVendor
do you have a G-80 or open diff?
if you do alot of highway driving i would suggest 3:73s
Both gears are very streetable
If you have one wheel peel then you will want an aftermarket LSD
If you have a G-80 then i would suggest getting a aftermarket LSD. You might as well change it now why you are there.
good LSD's
Eaton LSD
Detroit tru trac LSD
yukon Duragrip LSD
Some good gears:
Yukon
Motive
good LSD's
Eaton LSD
yukon Duragrip LSD
Some good gears:
Yukon
Motive
CammedZ71
08-02-2015 01:44 AM
iregret
07-27-2015 10:32 PM
lxcoupe
07-14-2015 10:14 PM
