Gear swap trying to choose a new Locker
For anyone intending to use the Eaton LSD with the available 800lb springs (400lb are standard), they will cause the differential to act even more like a locker during normal and especially wet weather driving conditions. This really stands out in a lighter vehicle where it may be easier to slip the tires instead of overcoming the spring pressure to unlock the clutches. The standard 400lb springs are usually adequate for most people’s intended use, even occasional strip use. Also, for those that do go ahead and step up to the 800lb springs, it is quite common for the end user to have to service the rear axle on a little sooner interval, as the clutches tend to want to stick a little more with the added pressure and the owner may notice noise or tire hop during tight turns. Frequent servicing and sometimes even the use of an additional bottle of friction modifier will eliminate these conditions.
I think you meant a Spool for those 800# springs.. they dont slip much at all!!
I was gonna get a rebuild kit for mine just to have in the shop and was talking to my buddy at the powertrain place. he said most people will bring them back wanting the 400# springs.
but yea i see what your saying.
i have a Truetrac in the front of my samurai and hopefully it works like it should
I also feel the TruTrac is an excellent choice for a front differential application, such as what you've chosen for your Samurai. Too bad the little 8.25" GM IFS axles aren't strong enough to handle anything other than an open carrier.
My experience with a detroit locker was horrible. I would strongly advise you to take it off your list. It was very loud and crude. Parking and tight turns made it feel like you were fighting the steering, tires chirping, and then if it unlocked it would make a huge BANG! The detroit has a lot of slop between the locking teeth and when spinning wheels, at the moment when the tires go from slip to traction, I had what felt like violent wheel hop. It was actually the locker clanging around like an impact gun.
Last problem... when going around a corner, if you accelerate hard out of the corner, and the locker "locks" its difficult to control.
I replaced mine with a wavetrac and it solved all the above problems. It probably isn't available for your application, but the trutrac is similar in design.
10 Second Truck Club
Valuetrac ftw. I got mine from Rons machine. Lock when its supposed to, can run around parking lot without any trouble/noise. On my rcsb around a corner fast enough will cause the axle to lock and hop or shudder during cornering but only when u get aggresive on the gas pedal.
I talked to one of the techs at Eaton and gave them all the info my goal HP, goal tire size, how I use the truck and he pointed me to a Truetrac for my truck. I was going to get the LSD with the 800 spring and he said you have to change the friction material from carbon to steel and it would be basically a spool. Thanks for the input everyone and when I do the swap I am going to do a 3.42 before and 4.88 after video showing the difference.
How can I tell which locker I have? I didn't install it, and the shop that built it has been less than truthful with me, as I have found many things not to be what I was told I was getting. I have a bunch of numbers that are engraved/stamped on the locker and some pictures if that helps. If anyone here can help, what do you need from me to determine what locker I have?
I've developed some slop in the driveline and traced it back to the locker. All my gears and U-joints are tight. I jacked up the rear and placed jack stands under the axle. I can rotate the rear wheels 7 1/2 deg before the locker turns.
Thanks
Thanks
